Got a H/K 730 receiver with no previous ownership history, and guy that gave it to me to look at said it was popping the internal fuses. Looks like the fuses next to the filter caps (pictured)
I pulled the amp board and checked all four output transistors with a component tester and they all passed and are working. The amp board itself looks totally fine.
The fuse labels read 2.5A-125V S.B. - does the SB mean slow blow fuses instead of regulars? The manual doesnt specify either way.
What/where should I check next?
And would it be okay to power up the unit without the amp board connected to see if the fuses still blow?
EDIT/UPDATE: Issue was the bias diodes on the amp board
