MCS Guy
The MCS hoarder
I just wanted to make sure these voltages were right.
Pin 1= Not used (Cathode feeds Supressor Grid from this pin internally)
Pin 2= 0 (Cathode/Heater GND)
Pin 3= 504 VDC (Plate)
Pin 4= .400 VDC (Screen Grid)
Pin 5= 0 (Supresor grid)
Pin 6= -21 VDC (Control/Bias Grid)
Pin 7= 7 VAC (Cathode/Heater Power)
Pin 8= .400 VDC (Screen Grid)
These readings were taken after 10 minutes of run time. Just wanted to make sure these readings are healthy before buying new outputs and the big caps.
Also, Output Trans A resistance was 138ohm and Output Trans B was 142ohm (measuring from center tap to pin 3). Is this OK?
