random_noise
hello all, here are some pics of my new preamp.
wanted this for a long time, it's a perfect match to my power amp (same manufacturer)
specs:
2 x 12AT7 in class A
maximum output 50 Volt
thd 0.1% 1KHz
freq. response 5Hz – 300KHz
s/n 85 DB
input impedance 47 ΚΩ
output impedance 1000 Ω
power consumption 60 Watt
weight 6kgr (mine is a bit heavier, there is some extra wizardry going on in the psu section)
42x35x14 cm
specs:
- Five (5) Line Inputs with Tape Out.
- Alps Volume Control.
- Matched Input Tubes.
- High Grade Selection Relays.
- Three (3) Independent DC Power Supplies.
- Double Face Printing Circuit with Separete Signal & Power Path.
- Power Supply Capacitors United Chemicon.
- Porcelain Tube Bases.
- Hand Made Power Transformer.
- High Grade Polypropylene Signal Capacitors.
- Metal Film Resistors with Low Tolerance 1%.
- Gold Plated Input Connectors Ultimax.
- Gold Plated Output Connectors Ultimax.
- Five Years Guarantee.
thd 0.1% 1KHz
s/n 85 DB
42x35x14 cm
