Hello guys! I am new here and after a little bit of reading I got impression what a great and experienced community you have here. So I decided to post here my question about repairing amplifiers as well.
Recently I've got faulty Onkyo Integra A-8650 as my learning repair project. I found that one channels output transistors were blown so after a lot of measuring I found all (as I expect) malfunctioning parts and replaced them.
Amplifier is working again, but I have concerns about output transistors getting really hot on one channel different from that I worked on (not sure how hot is bad but after 5 mins I can't hold finger on them). I measured dc offset
and I've got 1.5mV and 2.5mV than I measured dc voltages on output transistors:
on hot channel Q609 emitter 0.09V and Q611 on collector -51.0V
on channel that I worked on Q610 emitter 0.018V and Q612 -50.8V
Things I've changed on this hotter channel is R902 I have placed 12 ohm 2W metal oxide resistor instead of 13 ohm 1W wirewound. And D507 to 3.9V 0.5W Zener. All caps in amp where measured with esr meter and bad caps were replaced with the same new ones.
So the main question is where to look for a clue and how worried should I be?
Any help would be really appreciated!
Cheers.
P.S link for the schematics:
https://drive.google.com/open?id=0B8KUNmX2TYSUOU1VbkdGRUs2S1U
Cheers.
