janikphoto
Lunatic Member
any reason why I should avoid getting an Otari MX5050bII to replace my current Teac 10” player? I know Otari is one of the Studio standard brands.
I have a recently acquired and refurbished MX50 1/4" 2-track machine that is quite superb. The machines are extremely mechanically robust as they were designed for professional use in studios, radio stations etc. and employ largely common record/readback electronics and head designs so there is a consistent brand audible signature. The MX5050 has much in common with the MX50 and MX55 although the tape handling mechanism is somewhat less "pro".Some new parts are available through Aheadtec in California. Including heads.
If it's a BII or a BII E and still has its original head configuration then that's how it should be, however they can be custom configured in the field so you'd have to confirm that it's a full two track recording head. Most likely it is, anyone buying a semi-professional machine like this isn't likely to want quarter track recording function. Also it only runs at 7 1/2 ips and 15 ips so no 3 3/4 ips use (unless customized for it).
EVERY B II I've seen has had a switch on the rear PCB for switching speed 'range'; i.e. LO for 3-3/4 - 7.5 and HI for 7.5 & 15ips.
And don't get fooled by quarter track vs. 4 track - or verse visa
I just bought a really nice 5050 bII 2 this last weekend ... What a stellar machine!
If you lift the door over the head block, you'll see the 2T/4T switch to select 2 track or 4 track playback.
Good to know regarding the speed range selection, makes a lot of sense to build in the option. Does it handle the recording and playback EQ change too or does that get done separately?
I wish the industry hadn't started calling 1/4 track stereo "4 track" BITD, it really confuses things. I also hear people calling 1/4 track stereo "2 track" which annoying, then I gotta get a pen and paper out and start drawing the track diagram.
Hmmm ... I'll have to look into that sir. What's the story?Yes... and be SURE you're in 2TR when recording or you'll get - ah, "interesting" results!
From everything I've read, the switches (front & back) take care of EQ etc.
DAMACMAN: be sure to remove any FOAM on the inside of the rear metal cover and clean very well (alcohol works w/toothbrush) the circuit bd where it had been resting against. It can cause headaches.
old rotted foam has strange effects on the ele. components/circuits. Why was it there? Don't know for certain - perhaps to dampen the sound of solenoids & or relays. That rear cover has lots of surface area to resonate on... YMMVHmmm ... I'll have to look into that sir. What's the story?
calling qtr trk stereo '2trk' is just WRONG.Good to know regarding the speed range selection, makes a lot of sense to build in the option. Does it handle the recording and playback EQ change too or does that get done separately?
