Sure is , will cost $79. For a vividline 1800s stylus to bring it to its top level.Found this amongst junk... I hadn't been in this box in 20 years. No stylus. Worth messing with?
Cool, how does it compare to, say, Audio Technica or Shure cartridges? I don't even remember where it came from, I'm sure I got it from someone back in the 90s. You can see that Shure V15 IV beside it in the box.. that's the one where I used needle nose pliers to remove the wire from the back, and the whole terminal board came out, ruining the cartridge. I don't know why I kept it, it was an early lesson on being careful!
The XV-15 is a MI cart. I found it to be dynamic with big bass and sweet highs, although I struggled with a bit of sibilance with it, perhaps due to the stylus I used or alignment imperfection. If I had a complaint it would be the metal mounting "wings", which I found to be fiddly, especially with the little rubber mounting blocks it came with. The wings and rubber blocks would twist when I turned the mounting screws, compounded by the little metal wings being flexible as well. It all made mounting a bit of a chore, but there was a warmth and charm to the cart that make me understand why many enjoy this cartridge. It's a cart, like the V15, that long-term hobbyists owe themselves to try at least once IMO.
How about arm/turntable compatibility? Looks similar to Shure in that regard, fairly general purpose? My parents were cleaning out their computer room, and presented me with that little wooden box, which I hadn't seen in years.
One of the other members had posted this chart in a previous post, original stylus and their intended purpose.
Well I used it on a PLX-1000, a common S-shaped arm and it worked well. Remember too that there are styli from heavy-tracking conicals up to light-tracking special tips for this cart and the Stanton 681, so there are plenty of options for marrying compliance, VTF, etc, for your needs. Someone with more detailed technical knowledge of cart/tonearm matching can chime in more effectively here I'm sure.
You mean to say, I could use any of those styli in the body I've got?
If that's the case, this is quite a useful find!
Yes to both.
absolutely, you can swap out a heavy tracker dj type stylus for a very fine tip hifi sound in 3 secondsYou mean to say, I could use any of those styli in the body I've got? If that's the case, this is quite a useful find!
yes ,not for a stanton 500, for the stanton equivalent 681 i thinkCan I use the Stanton DJ styli?
