I took this amp in trade a while back, and I did so knowing that one of the output transformers had been replaced with a Stancor (unknown specs). I have been browsing for a correct transformer while I work on other projects, run an ad on Bartertown & ongoing searches on other sites, but no love. I have found other Pilot EL84 push-pull amps & receivers but they use different number transformers. The SAMS for the 240 does not list a replacement transformer (other than the Pilot one), but does list the specs.
I have not done anything to the amps as it sits, not power with variac or DBT. I was hoping to locate a transformer before starting.
So, do I just continue to be patient? If I decide to use another transformer or presumably pair of transformers (like ones from the EL84 version of the 903 for instance), what issues do I look for? Or other suggestions (I have enough boat anchors already so don't go there)?
Thanks.
Thanks.
