Leokarma
Well-Known Member
My pioneer 980 had developed a problem which I'll try my best to explain.
When I turn it ON, it starts normal i.e. the relay will engage within 4~5 seconds and the receiver will work with perfect sound. But once in a while (within few minutes to any hour) the speaker will make a loud "Thumb" (for fraction of a second) and the relay will disengage and then engage again within 4~5 seconds. Sometimes this will happen within few minutes and sometime the receiver might work OK for over 30 minutes. When there is this "Thumb" noise both watt meter needle goes to extreme right (only for fraction of a second). I'm unable to zero in on the problem and need someone to help. Just fyi I do have another 980 in my attic with bad FM board and if required I can use power supply, protection or other boards from that. The problem is that I'm not sure on where to start.
