Pioneer CS-33
Discussion in 'Speakers' started by arcaidy, Aug 1, 2010.
  1. arcaidy
    arcaidy Active Member
    411
    Atlanta GA area
    Picked up a pair from the GW today. Can't say they are anything special, but look nice so I figured why not. Anyone know much about them? Cabinets seen pretty nice.
  2. vintage4
    vintage4 Active Member
    285
    Some of those old pioneer speakers are surprisingly nice sounding . Especially if you don't feed them too much power . Power rating on those is 25watts I bet they'll sound great with a valve amp .
  3. Dr. Mordo
    Dr. Mordo Doctor of Rockology
    644
    Conway, AR
    Yeah, I've read about several with shredded surrounds on the woofers, and they can't be repaired because it's a paper surround, so go easy on them.
    But, I demoed a set of CS-33As, and they were a pretty good little speaker. They a had a lot of character, a fairly flat freq curve, with a very controlled treble response. The tweeter had a very slight distortion that made it sound very cool.
    I posted about it here. You can find it if you search.
  4. B3Nut
    B3Nut tubes and spinny things!
    1,983
    south central Wisconsin
    Interesting speakers, lettuce know what you think! Did you get 'em for a small amount of cabbage? :D
    <ducking> hehehehe!
    Those *are* quite cool...AlNiCo no less. From Pioneer's tube era, I bet.
    TP
  5. arcaidy
    411
    Atlanta GA area
    So should I leave the original cap in place or change it out? They really don't sound bad for what they are. I have a couple of small tube amps I could drive them with....
  6. Dr. Mordo
    644
    Conway, AR
    Replace the caps. They may be fine, but it certainly won't hurt the sound.
  7. vintage4
    285
    If you've ever priced a brand new fullranger that uses alnico magnets it will make you want to hold on to those . There seems to be a slight resurgence in the use of these type drivers . Some of those old alnico pioneers are selling on Ebay more than they were as brand new . I see yours have the removable back panel aka BBC/Harbeth loose box method technique . How much did you get them for ?
  8. wmcla45
    wmcla45 New Member
    13
    Lititz, Pa
    Cs-33's
    I found a set also at GW about a month ago for just over six bucks. All original parts, I did check the woofers and gave them a shot of hair spray to stiffen them up. To me they sound pretty good in a small room, I do have to be careful with the SX950, as it could easily damage them. I am looking for some larger Pioneer speakers, but for now these work fine.
