Hi everyone,
This is my first post here, so I apologize for jumping directly to asking question without introducing myself first. But I have my beautiful and beloved Pioneer SA-7500 that has got a strange issue on one channel that I have not been able to fix. I thank you in advance for any advice will be much appreciated.
I did post about this issue in another popular forum here in Australia but unfortunately the problem was left unidentified. I am really counting on the experts here to point me to the right direction.
The main issue is that the bias current is 0mv on right channel. Left channel works and sounds fine. The R channel of course outputs a weak distorted sound. Turning the bias trim pot doesn't seem to have any effect.
In my attempt to fix and narrow down the issue, I have tried the following:
- Replaced all of the following transistors on both channels
2SA726 -------> 512-KSA992FBU
2SC1451 -------> KSC3503DSTU
- Checked all the transistors (including driver and power) on the faulty channel using the junction check method. Both NPN and PNP types measure the voltage drop of roughly 0.6v on base-emitter junction and nothing on collector-emitter. Though the output transistors only showed around 0.5v drop but it also measured consistently on both pairs.
- Swapped output power transistor pair between the channels, problem remains same.
- Swapped bias diodes D2-STV4H between channels, problem still remains same. I can measure -2.1v across on each channel diodes (positive lead connected to cathode).
- Have checked the trim pot in R channel using multimeter, it seems to be working as i can measure varying resistance as I turn it.
- Have checked most of the resistors and they all seem to measure OK.
- Visually inspected each component on power amp board, nothing looks odd or damaged.
- I have also recapped the amp with Nichicon PW caps for power supply and Elna Silmic for audio boards.
- DC offset measures within spec on both speaker terminals.
I tried to take some voltage readings on the R channel and I found the base voltage on one of the driver transistor 2SB527 is off. As per service manual it should be -1.2v but it measures always somewhere between -200mv to -500mv based on the bias pot setting. Collector voltage looks ok at -40v. The other driver transistor 2SD357 measures OK with around 1.2v on base and 40v on collector.
After all the above, bias voltage still measures 0mv on R channel and it sounds distorted. L channel sounds fine.
Please note that I am only a diy enthusiast and still learning as and when I can. So please excuse me if I take a while to follow on an advice or if I ask silly questions Any help will be much appreciated!
Thank you.
Thank you.
