100
MILLIVOLTS
what avionic was gently prodding about was using the correct units.
100 volts at those test points is impossible without "severe tire damage".
ok, now the phrase:
Worked on mono, dead on stereo
exonerates your work on the power amp. MONO working means that the switches somewhere are not passing along the signal for that channel, so when the "switch of last resort" MONO is turned on, the signals from both channels are connected together. Check the manual's block diagram for the "control section".
S20 is mono, while one or more of the: function selector switches (AM, FM, PHONO 1, PHONO 2 & AUX ), TAPE 1, TAPE 2 & ADAPTER switches may be interrupting the signal.
the cure: deoxit and exercise.
And yes, 100mV is high, 50mV is also high, while 35mV isn't LOW.
The setting determines where the point is that the amp switches over from class A operation to class B operation, and realistically - somewhere lower than that is the distortion "knee" where further increases do NOT decrease distortion, only increase dissipated heat.
edit: the guys beat me, because I stopped to get and open up the service manual....
