I am the proud owner of a Pioneer SX2500. A few days ago, repaired the L channel as it was straight forward. What is not straightforward is the autotuning feature. The motor runs back and forth as does the dial pointer without stopping on stations.I do receive about 48 stations in stereo if the antenna behaves. I have scoured the internet and read about the Motorola patent application in 1966 and a more complicated patent in 1971. However I think the 1966 patent is more applicable and has a 19Khz pilot signal that is amplified and terminates the dial pointer search when it reaches a station, as signified by the amplified 19Khz signal which in turn turns off the motor. I have a
Telequipment S51E 3MHz oscilloscope, Eico 377 function generator, Sencore SG165 AM-FM-stereo analyzer,Iwatsu SS-5702 20MHz dual channel oscilloscope
and visual analyzer as tools. Also have replaced about 5 transistors, and three capacitors on the muting, autotuning, and the indicator unit.
