Pioneer SX-990?
Discussion in 'Pioneer Audio' started by SoCal Sam, Sep 16, 2008.
  1. SoCal Sam
    SoCal Sam Lunatic Member
    16,227
    Is the Pioneer SX-990 a real Pioneer product? I saw one this morning and it looked like a knockoff of a SX-750 or SX-780. The Pioneer lettering was different and the looks were low rent.
  2. tarior
    tarior Dirty pool, old man?
    5,249
    Kelso, Washington
    Yes, it is a real Pioneer product, ca 1969-70, IIRC. It's actually a pretty good little receiver, and it even has preamp outputs, and a decent tuner.
  3. Retro Stereo
    Retro Stereo Moderator Moderator
    6,801
    Owatonna, Minnesota
    Doesn't the SX-990 also incorporate a built-in reverb?
    I've heard good things about them, especially the build quality.
    Retro
  4. tarior
    5,249
    Kelso, Washington
    No, on the built in reverb, yes on the build quality. ~30 lbs for 27wpc, not bad.
  5. Retro Stereo
    6,801
    Owatonna, Minnesota
    Oh yeah, that was the SX-9000 I was thinking of....
    Retro
  6. Detailman
    Detailman Addicted to tweaking
    2,138
    Daytona Bch. Fl area
    Not like the 750 with the shelf on the rear.
    It does have the european type speaker holes on the rear but was sold with adapters in the US. You can use thin wire inserted in the slots and it will work fine. CAT-5 works great.
    Dececnt little unit with a nice phono stage.
    JMO
  7. kydog
    kydog Super Member
    I have a SA 900 and I believe the SX 990 is in the same line but with the added tuner:scratch2: Great solid build and 80 WPC ( SA 900).
    Just won a Sx 9000 off the "Bay" with the built in reverb:music: It's a beautiful looking receiver, Will post pictures later.
  8. whyaskit
    whyaskit music. Subscriber
    3,048
    Utah
    I had a 990, second best Pioneer I ever owned. I actually like the looks with real walnut cab
  9. porphyriaboy
    porphyriaboy New Member
    38
    ..in the center of appalachia
    I got one from ebay for about $10.00 It is pretty...haven't even tested it yet. I would guess that, if the adjustments and parts haven't "drifted" out of spec the tuner should be great. We have two stations worth listening to. Everything else is clearchannel drivel, country or pop, two choices. The 990 IS heavy...anxious to hear it...
  10. blhagstrom
    11,857
    Duvall, Washington
    Yes
    http://www.classicaudio.com/value/pio/SX990.html
    I fixed one of those for a friend. Part of the repair included a re-cap of the amp. I was very impressed with the tuner and the sound after getting working right. I see $300 MSRP in 71-73. Pretty decent price for the time period.
    To me, it had that warm, mellow, throaty "tube like" sound. The early Pioneers that I've heard seem to all have that sound.
    I LIKE them. :thmbsp:
  11. Cloth Ears
    Cloth Ears Well-Known Member
    555
    Melbourne, Australia
    Single-ended push pull design. No wonder the sound is so good. If my darling SWMBO had not put a stop to my buying, then I'd be picking up one which is on the 'Bay locally as we type...
  12. andrykowski
    andrykowski New Member
    2
    this is my first post, and i hope im not hijacking this thread, but i recently obtained one of these beauties from a relative. its been kept in a climate-controlled room and hardly used for the past 35 years. i hooked it up today and it turns on and performs its designated functions (switching am/fm, phono, aux), but the sound is very muted and there is almost no bass. its not the speakers and i tried several sets of speaker wire, to no avail. my next step is to get some contact cleaner and clean everything out. are there any other suggestions, short of replacing all the caps? thanks in advance
    edit: alright, so it turns out the mute switch was intermittent and activating itself randomly. i had the volume all the way up and was getting some crossover noise, when i tapped the panel beside the switch and got actual sound! now, my left channel isnt working, in both the a and b speaker set. i switched plugs and speaker outs, messed with the balance control and it seems the entire left channel is non functional. any recommendations for this? thank you again for any input or insight.
  13. larryderouin
    larryderouin Do I get Food, Med's, or more gear this Month? Subscriber
    18,863
    Glen Burnie Md.
    Open it up and clean EVERY SWITCH, POT, and CONTACT(Headphones, etc) on the Front AND the back, with D-5 De-Oxit FIRST. This should rule out poor contacts in them. Read "The IDIOT's Guide to De-Oxit, Revisited" here.......
    Follow the directions for the De-Oxit in the thread. You'll more than likely need the Service manual to open it up correctly. Get it INSIDE all the Switches, and Pots thru the slots and holes in the cases. Exercise the living hell out of them.
    Let it dry out for a while, then power it up with the Volume @ ZERO (all the way off). Then slowly increase the volume. It should work.
    Larry
  14. andrykowski
    2
    thank you much for the link. i know a little about deoxit and amps in general from my guitar playing days, but the rules regarding hi-fi are a little different. thanks again
  15. blhagstrom
    11,857
    Duvall, Washington
    expereince
    The one I fixed for the friend had some work done once.
    The resistors near the main ouputs were replaced on one side (and perhaps some of the driver transistors, been a while).
    When I got to it, it had a weak channel.
    It turned out to be a bad resistor on the other (non-serviced) side.
    The amp section is not too complicated, tough to find much info, the SM is almost useless but AK threads have a lot of info.
    Look closely at the big resistors on the top of the amp board. The one I worked on had some corrosion on the legs.
  16. Japetus
    Japetus Nightshift
    199
    North West Germany
    blhag, you're not talking about the newly (couple months ago, http://akdatabase.com/AKview/thumbnails.php?album=44&page=2) provided SM, which contains all board layouts/cirquit diagrams including main amp unit w15-060, the complete parts list up to dial cord stringing and FM alignment instructions, do you? :D
    Frank
    Quad4Life likes this.
  17. Malone
    Malone Member
    53
    Europe
    Yap, great unit until you have to clean it:smoke:
  18. Anubis
    Anubis Super Member
    3,270
    I used to have one. I sold it recently. Great tuner and built like a brick chickenhouse. Not the most attractive reciever on the block (although I did like the touch of using different colors for the function indcators), but it has a throaty tube-like sound. I liked the sound of mine and it even had the speaker adaptors.
  19. eckmyredavid
    eckmyredavid New Member
    1
    I have a SX-990 in for repair, and all the wires were busted off the output board. Some tracks/terminal pins are broke and missing. Every time I think I have it figured out, I only got one side, then in re-wiring, lose it with a 'thumping pulse' sound with neither side working. I was looking for a nude shot of the wires connected to the output card, but the closest I came was a reworked one without the wires connected. CAN ANY PROVIDE ME WITH THE WIRING assignment to the output board? I think it's the ground wires I'm messing up. I believe all the grounds go to the E markings, but I'm not sure which ones....
  20. markthefixer
    20,383
    Bensenville,Illinois
    what documentation do you have? the AK database has an 8 meg service manual that shows the board's foil side and connections clearly.
    http://akdatabase.org/AKview/thumbnails.php?album=44&page=2
    then there is the schematic here
    please don't be insulted, but are you starting out at minimum idle current with the 50 ohm pots zeroed? otherwise the idle current could be way too high.
    maybe tonight I can dig the 990 out of the pile and open it up for some pron. if it's internal condition is useful.
    posting photos at the res the board allows is limiting, PM me an email address to send a larger file to if I manage to get some shots.
    or maybe a list of wire colors.
    dlucy likes this.
