I have been wanting to change a lot of my power cords for a while now as I have had issues with cheap and miss match ones.
Between all the power amps in my system, my Martin Logans and sources I need a lot of them. I'm always hesitant in buying ones that I want to afford because I don't know the quality of the wire and shielding.
Needs
Very good looks
Superior Shielding and isolation
I guess they all need to handle 15 amps or more?
I would like them to feel good and be able to flex and lay flat.
As far as what I think looks good is black and or dark color. The end result would be elegant and not flashy hot rod tacky colors.
And with this one you can see a added wire coiled around the cable for added shielding.
I would need good quality and looking plugs.
I will need cable and it doesn't matter what that looks like as it will get covered. But want quality and very good flexibility, but not springy and will lay flat.
I will need the net type covering, again not to plasticy more like ballistic material that flexes nice.
I have a store with and heat shrink I need
Needs
Very good looks
