I bought this unit used about 6 months ago and have had no issues with it since I set it up. In fact I loved the sound that came from it.
I was using it to run the sound from a Samsung TV, through the optical link, and running it into an aux input on my amplifier. I also ran a USB to hook up to my laptop if I wanted to listen to flac files from my collection.
Everything was working great and then it wasn't. So now I have tested all inputs and outputs. It has 2 Analog Inputs (A & B), and 3 Digital inputs: USB, Optical, and SPDIF. It also has 3 Outputs LINE OUT, TUBE OUT, and DAC OUT.
Analog IN A and B work fine and the LINE OUT and TUBE OUT work fine. However The USB IN and the optical IN do not work. Nothing. Not static or anything. And I get no signal from DAC OUT
Essentially it appears the actual DAC does not seem to work.
I popped it open hoping perhaps I could see something was obviously amiss, but no, nothing.
Is it possible to repair this unit? Or is it a situation where the cost would be greater than the cost of a new unit. Also it appears the Grant Fidelity site is down as I went to look for info there.
Does anyone have experience with this issue or repair?
Thanks!
Thanks!
