Going to have one of these pass through my hands soon, am very excited to have a look at this classic amp. I want to do as little as possible to make it work properly, without harming the market value. This one is really clean, comes complete with the original box, and mono preamp, but the output tubes have been changed to 6L6GC at some point. There's even the manual, and original receipt from 1957.
I'm imagining that the electrolytic and coupling capacitors will need to be changed. Am thinking to change out the 0.1uf coupling capacitors with the Russian PIO capacitors (mostly to preserve the under chassis appearance), the 0.1uf cap between the screens of the EF86s with a metal film capacitor, and the 16uF filters can be changed to 22uF 450V electrolytics.
I'll measure all the resistors and change whatever is bad.Obviously test the tubes and change what's bad.
Does this sound reasonable? I don't want to do more than is required to make it work properly, and leave as much original as possible for the next owner. Do any of the old caps hold up OK over time, or is this an amp where I should just change them? I feel like there's some trade off here between selling an amp which doesn't work, and runing the value by making it non-original.
