WntrMute2
Super Member
I have built this amp with the changes shown in Red. It sounds very good driven with a Cary 9SLP-98 into a pair of Heathkit AS-21. I do have a couple of questions hopefully someone here can answer.
1) At the input RCA jack i have substituted a 220K ohm resistor for the 100K ohm pot to form a grid leak circuit.
I was hoping to reduce the sensitivity of the amplifier as I can barely move the volume control off idle on the pre-amp. Would changing back to the pot at 100K (or some other value) help in this regard? Adjustment in level would be nice as my left ear is down a few decibels. I'm concerned that running the input signal current through a pot or resistor may degrade the SQ. Is this something to be concerned about?
Suggestions as to how to add adjustable attenuation would be appreciated.
2) The output when measured with a RTA and pink noise shows a significant decrease above 10KHz. I've tried another pair of drivers that are supposed to play a little higher but the measurements are very similar. Any thoughts on changing cap values or something else to boost the top-end a bit?
This is my first foray into building off of a schematic so I appreciate and and all help and information.
Thanks
Thanks
