Raspberry Advice Please
Discussion in 'PCs & Music Servers' started by shacky, Apr 24, 2017.
  1. shacky
    shacky Addicted Member
    8,296
    Rochester, NY
    I want to setup up dedicated server for my Logitech Squeezebox system - I have 2 SQB's one in LR and one in office. I've been doing double jump from my laptop and have been having too many troubles. When I hook up my laptop to wifi router it works perfect.
    So how would I setup a Rasberry Pi to accomplish same? I have a NAS I can use or a USD HD. I'm fairly computer savvy but not that great. And I want to maintain Logitech SQB with control via iPeng.
  2. shacky
    8,296
    Rochester, NY
  3. ldatlof
    ldatlof We are all steak Subscriber
    2,803
    Las Vegas
    A Raspberry Pi will work perfectly and is cheap. Install Raspian OS, install Logitech Media Server then plug in RPi to your wireless router. Setup LMS to use either your USB HDD, which I imagine will be plugged into the RPi, or your NAS, that is up to you.
    derekva likes this.
  4. nbndtrain
    nbndtrain Active Member
    442
    Denver, CO
    Check out Max2Play. It's a plug and play setup for raspberry pi focused on Squeezebox functionality.
  5. E-Stat
    E-Stat Addicted Member
    5,648
    Pretty much the same way.
    I replace a Touch with an RPi in the garage using piCorePlayer and sounds better. It runs on my LMS based system very well. I too, am an iPeng user. :)
  6. Ned Blohard
    Ned Blohard Active Member
    294
    Ontario, Canada
    +1 to this.
    I have a SB classic hooked up to my main system and a SB radio in the kitchen. LMS is running on a Pi via Max2Play, connected to my router. Music is on a USB HD plugged into the Pi.
    Max2Play is pretty easy to set up... you might run into a few issues due to instructions being badly translated from German. I'm happy to help if needed.
    Runs beautifully, all controlled by iPeng.
  7. CT Jim
    CT Jim AK Subscriber Subscriber
    3,062
    Branford, CT. 06405
    Now that there are Raspberry choices, which one? Raspberry Pi3, Raspberry 83something.....
    I picked up a SB from another AKer and it's still in the box......
  8. ldatlof
    2,803
    Las Vegas
    Raspberry Pi 3 Model B is the newest board and is the one you want.
  9. patate91
    patate91 Well-Known Member
    627
    Chicoutimi, Qc, Canada
    My PI 3 is on his way. I planned to plug my usb HD and use runeaudio. Any thought on Runeaudio? The fact that I can use my cellphone to control it is a big plus.
  10. E-Stat
    5,648
    Some say it enhances the experience with its deep metadata and links about music. I'm not a user myself.
    I use both an iPhone and iPad to control LMS (sans Rune) via the iPeng app.
    patate91 and ldatlof like this.
  11. ldatlof
    2,803
    Las Vegas
    I haven't used it either. I use Squeeze Commander to control LMS (via Squeezelite players) with an Android phone.
    steady and patate91 like this.
  12. Hajidub
    Hajidub Chihuahua/Pug = Chug Subscriber
    4,998
    Colorado Springs, CO
    Have the Pi 3, it's great. Fastest of all the Pi's and built in wireless adapter.
    ldatlof and patate91 like this.
  13. patate91
    627
    Which OS are you running on your pi 3??
  14. ldatlof
    2,803
    Las Vegas
    I run Raspian because I like to setup everything myself.
  15. Hajidub
    4,998
    Raspian and Retropie (for gaming).
    ldatlof likes this.
  16. patate91
    627
    My first goal is to use a usb drive with a usb dac to listen to music. Is it easy to setup raspian?
    I like the idea if retro gaming console for the kids. I'll look at this.
  17. ldatlof
    2,803
    Las Vegas
    Yes it is easy to setup. Download NOOBS from the RPi website. A 10 year old can do it.
    I have used Retropie and it is very good if you like the old video and arcade games. It also makes a great Kodi box.
    You may want to look into PiCorePlayer. It is a very small OS that turns the RPi into a server (LMS) and a player (Squeezelite). Also very easy to set up and it enables you to use the Pi as a server only, a player only or both. It basically turns your pi into a headless Squeezebox.
    patate91 likes this.
  18. E-Stat
    5,648
  19. mars_volta
    mars_volta Super Member
    2,181
    I have a rpi 3 and zero w.
    OpenElec for media center (with myth tv backend on server) The Rpi3 recently replaced a veteran WD live tv box.
    Raspian for desktop
    Retropie for games
    Flightaware + RTL-SDR for ADS-B
    The zero w is headless. I VNC into it. It was dedicated to ADS-B but I have been using it to rip LPs from the Adcom system. I use Audacity and a Behringer usb sound interface.
  20. E-Stat
    5,648
    Or, for playback only as essentially a memory player using the remaining 600 MB of memory as buffer.
    ldatlof likes this.
