I've been working on an 1948 RCA Berkshire Breakfront unit (see pic below) for several years now and am finally getting to the point where I can begin to reassemble it. It's been a long hard battle, but mostly successful. I have a question for you phonograph cartridge experts.
Originally the system was equipped with a Thorens CD-40 78rpm record changer and a GE VR cartridge. Somewhere along the line the cartridge was replaced with a more modern ceramic type, and the preamp was removed. Several years ago I acquired a GE VR cartridge...but there's no model number on it (see pics below). I'm wondering if this would have been the cartridge that came with this unit? Also....I have a GE UPX-003 preamp, would this be the correct one to use with this cartridge? If the cartridge pictured below is not a 1948 vintage VR cartridge, what would be the appropriate one?
Finally....I did connect this cartridge up to the preamp (using alligator clips) and there was a lot of high frequency noise. I understand that I was not running it through a shielded cable, and was expecting possibly some hum, but not the high frequency hash I was hearing. I tried the cartridge on a modern solid state preamp, and got the same kind of high frequency noise. I was able to get some signal from it, but the noise is quite loud. Is the cartridge defective? I checked the DC resistance and it was about 460 ohms, so it's not open. Any suggestions...ideas??? Thanks. Bob
