There are so many requests for information on putting new belts on a CT-F900 that I have decided to chronical one of my latest AK commissions: the restoration of a a nice little Pioneer CT-F900 Cassette deck.
Rebuilding the transport of this model is significantly more difficult than performing the same job on the older CT-F1000 or the CT-F9191, but, if patient and careful the job can be done.
When I restore one of these beauties, I usually perform the following:
Please note that this particular unit had been subjected to some ham-handed repair work in the past, just in case you notice its lack of clean wire routing, etc. The photos were taken as the unit was coming apart, not as it was going back together.
To give you an idea of just how nice looking these decks are, I have attached a pic of it, before I began the work.
Rich P
1. Perform a complete initial functional test. This is to determine what repairs may need to be made, and to provide a reference baseline to compare to, in case my repair actions break something (it happens), and so I can provide a comprehensive formal quote to the owner (in case of a commission job). In some cases, it is not possible to determine all of what may need work, until certain prerequisite work is done, such as, when a deck will not play tape, record and play electronics canot be adequately tested. In such cases the quote must go out in stages.
2. Rebuild the transport (covered, in detail, by this thread). Unless the owner is local to me, all work described in this thread is mandatory. This is to ensure that the job is complete, so the expense of shipping does not need to be repeated.
3. Rebuild the reel motor (covered in a separate thread: CT-F1250 Reel Motor Rebuild (CT-F800/900/950/1250). This task is also mandatory. After 30 years, small DC motors with brushes and centrifugal speed regulation switches all need work. It is quite common for these motors to have dead spots at their age.
4. Replace the pinch rollers. This is expensive, due to the fact that they are no longer available as spare parts. We do have an AK specialist, Terry Witt ( http://www.terrysrubberrollers.com/ ), who is the master of rubber rollers and idlers. After 30 years, all rubber dries, and hardens, and glazes, even if not used (the effect of ozone and other environmental components). If the pinch rollers for one of these dual-capstan, TOTL, decks are not resilient and supple, they will squirt tape right out one side or the other, and your favorite, unreplaceable tapes WILL get eaten. Pinch roller replacement is not mandatory, but HIGHLY recommended, unless the rollers are beyond restoration by cleaning and rejuvenation (cracked, eccentric, pitted, etc.).
5. DeOxit all user controls and internal switches (they do tend to corrode and get dirty over 30 years). This is part of a basic restoration.
6. Complete REC/PB/Dolby alignment/calibration. This is an optional service, but if desired, the basic restoration is a prerequisite operation, since you cannot get stable performance for calibration, if the transport is not up to snuff.
7. Complete recap (replacement of ALL electrolytic capacitors: Recapping a Pioneer CT-F900 Cassette Deck. This is an optional service, but if desired, the basic restoration and a complete REC/PB/Dolby alignment/calibration are required, since recapping is likely to significantly affect the calibration, and the calibration requires teh transport to be fully up to snuff.
8. Once the machine is fully up to factory specifications, or as close as possible, the appearance is worked on to match, with a complete cleaning and polishing, inside and out, and connectors are DeOxited and Pro-Golded, and polished.
9. Finally, the unit is subjected to a full, comprehensive functional test, to ensure that all features are operational. Then the unit will get installed in one of my systems and enjoyed for several days, to ensure I have not missed anything. Then the shipping packaging is designed and built, to ensure that the unit will survive a drop off of the roof (shippers appear to do that).
Rich P
