Recommendation on a surge protector?
Discussion in 'General Audio Discussion' started by kuad, Nov 7, 2014.
  1. kuad
    kuad Super Member
    1,220
    Aventura, FL
    Hi there!
    Looking to replace my surge protector with something a little better. Do not need a ton of outlets. Anything good for $100 or less?
    Grateful,
    Dennis
  2. Seppo
    Seppo Work in progress
    1,243
    Ontario, Canada
    I have been _very_ happy with my APC H10 power conditioner and surge protector. It has protected my gear very well against any and all power spikes and brown outs.
    APC site:
    http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=H10BLK
    Amazon (~$200 thanks to substantial ~$170 discount) :
    http://www.amazon.com/APC-H10BLK-Conditioner-Discontinued-Manufacturer/dp/B000FBLOAY
    I am just thinking that since you are willing to budget up to $100, for a modestly higher $200 you would get a very good upgrade from a basic surge protector. Or perhaps you might be able to find a used H10 for less than $100...
  3. Condorsat
    Condorsat Audio Enthusiast
    4,722
    Ohio
  4. kuad
    kuad Super Member
    1,220
    Aventura, FL
    :scratch2:
  5. 68custom
    68custom Addicted Member
    7,249
    sarasota fl
    buy a whole house one and wire it into the breaker panel.
    I have one made by a company named "Transient Eliminator" which has been installed for years, seems to work good!
  6. J English
    J English Super Member
    1,119
    I'm using Tripp-Lite ones now. They are well-built, seem fine for basic protection.
  7. 1tumbleweed
    1tumbleweed Kozmik Kowboy Subscriber
    6,180
    Colorado Front Range
    Panamax and Furman make a whole variety under $100. The only other brand I'd consider is TrippLite.
    Happy trails,
    Larry B.
  8. bare
    bare Super Member
    1,987
    Do those things actually work?
    I don't have such ..so no direct experiences.
    However I do know those who do 'claim' theirs proved ineffective in protecting against a genuine power surge... as opposed to a minor variation type.
    So much so that a Lot/most of their electronics fried.
    Just asking?
  9. davidb1
    davidb1 AK Subscriber Subscriber
    2,541
    Sandy Springs GA
    If you can stretch your budget a bit, check out Price Wheeler's Brickwall. I have had one for 10 years and have been very pleased. Great customer service as well.
  10. 1tumbleweed
    6,180
    Well, Panamax' biggest customer is AT&T/Lucent - Does that tell you anything?
    Seriously, a well-designed unit will indeed protect your equipment from surges or lightning strikes. The cheapo units don't. As far as the "line conditioner" units...I'm not gonna open that bag o' worms.:no:
    Happy trails,
    Larry B.
  11. kuad
    kuad Super Member
    1,220
    Aventura, FL
  12. kuad
    kuad Super Member
    1,220
    Aventura, FL
    :scratch2:
  13. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,343
    NC
    I'm cheap, I keep my gear unplugged :smoke:
  14. sKiZo
    Local power company was offering a behind the meter unit ... about as "whole house" as you can get, ok. Paid around $150 for it 10 years ago, lifetime warranty, and they're on the hook for maintenance as needed. So far so good.
    I had a lightning hit here that fried the pole transformer. Only damage in the house was a dial up computer modem that was hooked up to the phone line.
    Oh. And my shorts ... <G>
  15. Poultrygeist
    Poultrygeist Lunatic Member
    I use this APC G5 Rack Power Filter which sells for around $100. Love it's sequential turn on/off feature.
  16. Spitfirejoe
    Spitfirejoe Cheap Audio Aficionado Subscriber
    833
    Fremont, Nebraska
    One thing to remember...
    Surge Protectors "wear out" - i.e., they stop protecting as well as they did when new. Each "hit" breaks them down a bit more. So, I buy a decent, moderately priced one and use it for a couple years. Then I buy another one. I have NO idea if "a couple years" is adequate...
    Batteries in UPC's wear out too. They get to where they won't recharge. Pretty easy to replace, and not too expensive. I just went to a "Batteries Plus" shop and they even installed the replacement for me.
  17. Kingshead
    Kingshead Professor
    3,633
    South Florida
    Units that mount in the electric panel are great for what they are, but don't be surprised when your equipment fails. These are more for protecting heavy electrical equipment like your range or AC, not sensitive electronics. You can never have too much protection so I would suggest more down stream from the panel, and even then nothing will protect everything all the time from every strike. This is the reason they are called surge protectors not lightning protectors, not much will stop a direct lightning strike. I've seen cinder blocks blown completely out of a concrete wall from a lightning strike.
    For an inexpensive power strip with protection I like the added feature of a master control receptacle this one has. If you connect your pre-amp/integrated/receiver into the master receptacle the equipment connected to the controlled receptacles will turn on/off when the main unit is. This is useful if connecting a tuner/processor/equalizer/etc that it would be convenient to have turn on/off with the main unit.
    Martin
  18. Condorsat
    4,722
    Ohio
    I was thinking along these lines too :yes: ... that's really the only reason I'm replacing my current surge protectors with a couple of Tripp Lites on my PC audio rig ... the units are old ... I don't want to think about how old. :nono: shame on me.
  19. whoaru99
    whoaru99 Epic Member
    40,898
    LoTL
    Under certain conditions they may help, and likely to perform according to the electrical principles and fine print therein.
    However, I think they're vastly oversold in regard to actually needing/should have one.
  20. WaynerN
    WaynerN AK Subscriber Subscriber
    5,987
    Minnesota
    A surge protector will not stop a lighting strike, at all.........
    BTW, I also use Tripp-lite. Cost effective and well built. Yes, the use MOVs......
