reinstalling tuner string
Discussion in 'Marantz Audio' started by michiganpat, Dec 29, 2010.
  1. michiganpat
    michiganpat Super Member
    2,681
    west coast of michigan
    did some work on my 2265 (redoing vellum, replacing a burnt out FM lamp), and in the process I had to undo the tuner string. anyone have any tips or tricks to getting the tuner string back on any easier?
  2. Punker X
    Punker X AK Subscriber Subscriber
    3,880
    Panic in Detroit
    Lots of masking tape to hold things in place and lots of patience .
  3. Fisherdude
    Fisherdude Regular Dude - Super Mod Super Mod Subscriber
    27,620
    Out West.
    Small alligator clips come in handy, too.
  4. sssmokin99
    sssmokin99 Well-Known Member
    936
    Kansas City
    Beg or borrow another similar Marantz, or the service manual if it has a good pic of the stringing path, etc. What you need is something to compare your work to- it is easy to route the string just slightly wrong, and it may work, but not very well and for not very long. And as Punker said, "patience"
    I can't stress that last one enough, lol
  5. catrafter
    5,791
    Montana
    This might help.
    Tom
  6. michiganpat
    2,681
    yes it does, I think I was going to put it on correct, but I might have had the two pullies on the right reversed...biggest issue I had was trying to keep everything from moving while attempting to wrap it around the tuner wheel, and where the last place to put it on should be? I"m thinking get everything set, then stretch over the pulley attached to the meter housing.
    I decided to hold off for a few days, I've got one more bi-pin light (the stereo lamp) out on it, and I'm waiting for a replacement from dgwojo to arrive....
    it's a lot easier to replace the lamp with the string out of the way...
  7. PacificStereo
    PacificStereo Super Member
    1,738
    It's also a lot less easy to hit the string with your soldering iron. Ask me how I know this!
  8. BeerLegs
    BeerLegs Super Member
    1,019
    Been there, done that....
  9. Punker X
    3,880
    Panic in Detroit
    I usually soak a paper towel with water and cover the string when I solder in the area.
  10. Coconuts 500
    Coconuts 500 Active Member
    468
    I usually cover the whole string area with a piece of cardboard. But the soaked towel thing sounds like a good idea.
  11. sssmokin99
    936
    Kansas City
    Join the club on that one, ha!
  12. clydeselsor
    clydeselsor Lunatic Member
    10,678
    N.W. Indiana
    I hate re-stringing a tuner more than just about anything!
  13. michiganpat
    2,681
    Tom-
    I just got the stereo lamp replaced (thanks dgwojo!), but the schematic you attached doesn't make sense--it shows the pointer going around the tuning wheel?
    also, the right side pulleys are in a different orientation than my non-B 2265....
    anyone have a 2265 they could take a nude pic to show the tuning string orientation?
    here's mine, with the string not on....
  14. BeerLegs
    1,019
    hifiengine.com has the service manual for the 2265. Perhaps it has a diagram in it. It's free. You just have to register.
    ...nevermind. I just checked and it's the Handbook of Instructions and not the Service Manual.
  15. michiganpat
    2,681
    I figured it out....only took 45 minutes or so to figure it out and get the pointer lined up correctly with the station....I found some pics of the 2265 in the nudie thread, albeit with the tuner string cover on it that obscures most of the string...
    also, even after vellum replacement, the display was still a touch green/aqua. the white lightbox was kind of a dingy yellow. a little lacquer thinner on some q-tips took a lot of the yellow away.
    for reference, this is how it goes
