The table can get the grommets from Ebay, there's a guy who sells new ones that fit it perfect. Also, when you clean the motor, draw a line on both halves so you put it back together the same way. Rubber new works on the idler wheels if they aren't that bad, otherwise Tery or VOM can do them over for you. The arm is actually pretty good and looks to be intact. The head shell can be found on Ebay as well, albeit, not that cheap. The notors on these sometimes take awhile to heat up, so you may have some "noise" coming through until warm. I redid a B-12H, and a Rondine Jr L-34.Both were very nice sounding tables. I sold both due to offers I couldn't refuse. Make sure the ball bearing is covered with enough oil so it's fully covered in the well.I redid the cap as well as took extra wood on the inside of the plinth and made it thicker but kept the original plinth. I redid it in a Colonial Red color. The arm likes cartridges that track at around 2 grams and up. Denon DL-103, Denon DL-300, Pickering V-15, Pickering /Stanton carts used with a brush, Shure, are all nice carts to be used on that arm as well.
