monkboughtlunch
Super Member
For the main ball bearing in a Rek O Kut, I've found the ceramic balls can cause a premature divot.
What type of ball did Rek O Kut originally include?
Any ideas on what the turntable platter stem is made from? And would a stainless steel ball or chrome plated ball be softer or harder than the platter's thrust bearing surface?
Additionally, it seems that ball bearings are more precisely made the lower the "grade number." Apparently, the grades range from 2000 to 3. So what is the minimum grade number to achieve optimal results?
Would appreciate any recommended brands / ball bearing model numbers to consider in a ROK table.
- Stainless steel
- Chrome plated?
- Other?
