Replacement Transistor has different pinout: 2SA706 vs BD14016
Discussion in 'Solid State' started by GW Hayduke, Mar 20, 2017 at 2:30 PM.
  1. GW Hayduke
    GW Hayduke AK Subscriber Subscriber
    19
    Hey guys,
    I'm replacing a 2SA706 with a BD14016 in my Sony TA-1055. I believe the pinout for the is E-B-C, and the BD140 is E-C-B.
    Stupid question, but to install the BD140, do is simply put the BD's base pin in the slot formerly occupied by the Sony's base pin? If so, is it difficult to "bend" the base of the new transistor to fit the center slot in the board, given that the BD's base is on one of the outside legs?
    Clear as mud, right?!?
  2. ivandezande
    ivandezande Well-Known Member
    962
    minnesota
    Yes....I think. You can of course bend the legs to match the pinout, but be careful that they don't touch. You can insulate the legs with very small tubing if you have it.
    dlucy and GW Hayduke like this.
  3. GW Hayduke
    19
    Awesome - thanks!
  4. dlucy
    dlucy dlucy67 (Doug) Subscriber
    687
    Yorktown, VA
    I had to do exactly that last night:
    ivandezande likes this.
  5. GW Hayduke
    19
    Thanks dlucy. Would you mind telling me what kind of tubing that is?
  6. dlucy
    687
    Yorktown, VA
    It is plain old heat shrink tubing from Harbor Freight.
    GW Hayduke likes this.
  7. Ray Gianelli
    Ray Gianelli Active Member
    428
    Lake Worth, FL
    In a pinch you can also strip some wire and use the scrap insulation.
    GW Hayduke and dlucy like this.
  8. dlucy
    687
    Yorktown, VA
    Excellent tip!
  9. GW Hayduke
    19
  10. NAD80
    NAD80 Well-Known Member
    628
    Carlisle PA
    Also if you can get it Teflon tubing works great. The size of the tubing is just bigger than the size of the leads of the transistors. Plus no worry about heat damage like shrink tubing.
    dlucy likes this.
  11. dlucy
    687
    Yorktown, VA
    I had to be extra careful when applying heat to the heat shrink tubing to avoid damaging the semiconductor. Methods like @NAD80 describes that don't risk the device would be better than mine.
