Depends on what you get as an output voltage, but I'd probably bump the value of R60 to adjust it. Can't quite read the value, but to guesstimate, another 10-47 ohms in that spot will probably make it right. Measuring the voltage drop across the existing resistor will confirm the current, and a little Ohm's law magic will tell you what value needs to be in that spot.
