Thank you!
This is how I got it. When I lift the plate with the head assembly the capstan stays where it is,and is "free" and now it's possibly with removal of the old belt and to put the new one back, right?
Remarkable it's still possibly to get belts, or are they new (sort of)?
ITeac X-300r
I imagine I have to continue with the large side screws? Photo 3?
Yes, you may need to remove the side/top panel to access more panel screws. I indicated more screws that need to be removed. Remove any screw on the panel basically.
After the panel comes off, then remove the headblock. Several screws hold that on. Make sure not to turn any head alignment screws.
Hello - I'm new to this - have a TR-3000 and having the same issue as Ralph9 - after removing all the faceplate items AND the 6 side screws, the faceplate still refuses to budge, except for a tiny amount at the bottom. Does one have to remove the back cover first?
Thanks! I looked up other old threads (possibly a few of yours) and it confirmed my hunch. My first serious dig into an R2R deck, tho I've repaired turntables, 8-tracks & cassettes before with broken/dissolved belt issues. This will be (ahem) "fun". Thanks again.Yes, you need to remove the back cover, the feet and the screws holding the metal cover on the TR-3000. Once the machine is all opened up you need to remove the screws holding the faceplate on from the inside.
