ok, here is the scoop, I am working a lafayette LR1500TA over in the solid state fourm. I am having a no fm problem and the guy helping me thinks its the 'ic's in the IF stage - I, like you, have 4 stages.
The culprit part, is essentially an early IC called uA703. while searching for a replacement I found some forums where people were complaining about the sansui 5000 fm section. IIRC, there is a schematic out there and the two circuits are very much alike.
that being said, in the part of the pic you blew up, nestled between the tuning slugs those dusty black looking transistor things with 6 legs are not mutant insect spiders, they are Ics of a sort that are likely uA703 or LM703's.
Go follow the thread I have, he gave me some tests to do. Find your schematic and print off, blow up, memorize the FM RF thru MPX section. What he has told me to do, is pretty much what you might want to do as well.
If this part is bad, direct replacements using the old part numbers are harder to find and about $6 or so. UTSource has em for $4 in IC format (8 pin dip) with $2 e shipping (whatever that is) from china, with a 4-6 week delivery. no thanks.
