Serial numbers just for the 990DB or all my other sansuis?Clean the function and dolby switches.
Please post the serial number for the database. Click on the link in my signature block.
- Pete
Ok I will check that board when I get home. Thanks Dougcheck you have +12v to ground at pin 01 on the RF power supply board F-2619; it's the small board behind the tuner signal meters. This board cooks itself; could be just a dry joint..
All of them if you can get to the serial numbers. The database is a great resource for determining when the units were built. It also helps estimate how many were built and can document production changes that frequently were not documented by Sansui.Serial numbers just for the 990DB or all my other sansuis?
60v I'm showingdo you have 40 or so volts arriving at pin 3 on that same board?
D313 transistor?The 303 trany
The D313 transistor?It's usually a combination of bad solder joints on the ceramic resistors and/or the transistor on the heat sink is blown.
- Pete
Is it this one?
