The Fuxtor
Addicted Member
Howdy all,
Finished recapping an AU-517 last month and all was great. Unit was working well before the recap fwiw... Started noticing that one channel was stronger than the other. Upon checking the balance with the units balance pot, I realized the actual pot was very "dry and scrapey " feeling?
Whipped out the deoxit and proceeded to clean the pot and followed up with deoxit f5 . Fast forward 15 - 20 minutes , check knob ( which was feeling quite silky and smooth) seems almost seized up.... Go through another deoxit round and the pot loosened up and seems better now.
Hook up some tunes and imbalance is still there? I have exercised the preout switch and it had been previously cleaned, along with tape monitor switches and all the usual suspects.
Decide to check with a multimeter...
Hook up the dummy load running a 1000 khz sine wave , compare one channel to the next shows approx 1-2% lower acv on the weaker channel. Hook up the signal directly into main in jacks and run the app ( using my phone's signal generator app) and compare voltages again and find the exact voltages left to right channel , no difference now! So it appears that the imbalance would be coming from the preamp board... What is the likely hood the balance pot has just worn out on the one set of wipers?? The preamp board received new Nichicon caps so that is ruled out now too. Anyway I can ohm out the pot while it is connected to the board ? Will that require surgery?? Something else I may have overlooked??
Charles
Charles
