Thanks for the heads up. Found it on VE. That's going to work just fine. Looks like it's very similar. Curious what the differences are? I have a few of these type of decks for the novelty and fun aspect of it. That would be programmable both sides play. A couple from Sharp, one vertical one horizontal. They sound decent but as you know they are limited. I do have an issue I still have not been able to resolve. The LP's appear to be warped when played. It's not the LP but when I look at the main drive platter, it appears to be true. When the LP is lifted for play the only thing holding them up is the center "puck" and that only covers the label. I wondered it this lack of support causes it to appear warped.
Belt used is a SCX4.3, inner circumference of 4.3, height of 0.045, thickness of 0.045. The belt seems to work fine. Is that the same as what you settled on? I am still dialing things in etc. but I think I like the Sharp unit a bit better in overall form. The top is flat and stackable with controls on the front where this, while flat, does need to have the keyboard exposed. However the function of the Sansui is much easier to deal with. Essentially it's two arms on one mechanism vs the Sharp where it's two arms and two mechanisms to deal with. More to come.
I think the Sansui sounds better from I can recall of the Sharp sound. More refined. I did replace all the stylii in both units so at least I am dealing with stylus of unknown use. Agree on W&F. Sharp is belt drive vs the DD of the Sansui. The lack of a real platter though has me bothered and a bit confused. When more than 2/3rds of the LP is not supported you seem to loose some of the benefit of the DD. The arm naturally will tend to move more on the outer grooves vs the inner as it approaches the support of the clamp and motor.
Waking up this thread, and hopefully you guys see it !
I have an Sansui P-L95R that operates just fine. My son swears the pitch is a little flat, so it needs a little speed adjustment.....OK, I said lets look into it.
1. I got the manual and a old non-working unit and took the thing apart as a test. This went good and the mechanism is not so daunting as expected. Getting the motor off is a little scary. Then I got stuck.
2. The manual's method of speed adjustment is just not understandable to me -- I don't get the entire resistor circuit etc. that I need to construct. WTF? I though it would have a pot I could turn with a "strobe disc"., but I have to completely dismantle the motor etc.
3. Is there an easier way ?
4. And what are the reasons the speed would drift on this TT?
Any help appreciated, and I can do something while stuck at home!
@maxhifi Thanks for the reply!
It works fully and every mechanism is OK. It's jsut this slight pitch flatness. There is no 'wowing' in the sound or anything. It's just it sounds like a tad pitch flat right through all LPs. My son's superman ear can tell that, so I need to just check the speed.
The problem is that I don't get the specifics the service manual says (it is attached if you are so inclined!). I mean i have to completely free the motor from its mounting -- it would seem unecessary just to get at the pots. These service manuals are written is secret code with relevant steps left out ! How else do I get at the pot?
Yes, I have been utterly shocked how good this player sounds every time I use it. Considering how 'extremophiles' pooh-pooh it because they see it as a contraption.
Yes, styli were changed first thing and drawer belt changed.
That is an excellent idea about fixing the strobe disc to the LP. However, as far as I have tried, it seems impossible to play an LP or even spin one if the cover and side has been taken off. The modules are all interconnected and the motor cannot be operated if the front/top panel is disconnected. I have to figure out that since the service manual offers no clues on that, or if that is normal.
It sounds excellent as far as reproduction goes, but there is this 'argument' that the speed is just a tad off. Its like the orchestra is playing in a flatter key than expected. So it is a minor thing, but requires major surgery?
Well said!
I just got done! Yay!
Yes, I used a trial and error method - took off the motor adjusted the pot, put it back, checked the speed ...repeat and rinse till the speed is right. Took a few tries but a good probe disc with the +/- 2% and 4% really helps figuring out which direction to turn the pot. Patience and care....
Thanks for holding my morale hand !
Lets see if it is still the same tomorrow. Ha!
