Rotoflex4
Hi all,
Found a modification on the F-2528 (Switch Circuit Board) of my TU-9900 Sansui. I don't know if this is a factory mod or a previous owner's handiwork. It's not documented in the service manual. Two traces have been cut, a jumper wire added and a 220ohm resistor installed. It is directly behind the Bandwidth pushbutton switch. I don't suppose anyone else has their lid off and can comment on what theirs looks like? (easily viewed from the top). Neither the Noise Canceller Switch nor the Low Pass Filter Switch seem to do anything when pressed (I mention this in case a modification has affected their functionality). Any insight? Thanks.
