I bought this from a fellow AK'er, who said that some work had been done to it & that it was working as-is. Both were correct, although it doesn't sound real good. The selenium rectifier has already been replaced, a 33 ohm 5 watt resistor replaced an 18 ohm, and the coupling caps were replaced with generic yellow film ones. Since I needed to order some parts for another project, I decided to get a parts list together for this too, even though I am still working on some other projects.
So some questions:
1. Some posts mention adding four 20 ohm, 2 watt resistors. Can someone spell out what this is about, pros & cons?
2. Current limiter? I have spare CL80's but see different ones used.
3. The diagram on the bottom of my case says it takes two 7199's, but has 6U8A's. I know that many folks switched from 7199's to 6U8A's or other similar tubes, but how do I tell if the correct changes were made to use the 6U8A? I don't see that any resistors were obviously changed around those two sockets.
4. None of the can caps have been replaced. Do I stick with the current values, If not, suggestions? One has two 20 mfd/450v sections & two 25 mfd/25v sections; one has four 75 mfd/75 voltsections, and one has four 20 mfd/450 volt sections.
5. I understand there are multiple schematics around, any easy way to know which version I need? Picture of the underside of the unit is below.
6. Any other specific suggestions/caveats?
Thanks for any help
So some questions:
Thanks for any help
