muscmp
i have a hum that has developed in my scott. it used to be that i could flip the phase switch and it would go away but no longer. it has been indicated on this forum that it would probably not be the switch causing the hum. all electrolytics except for the bias caps have been replaced so i plan on replacing them.
on the side of the two caps it is indicated that there are two 100mfd, 75v and one 10mfd, 75 volt. however, the schematic shows c5 having two 100mfd with no indication of the 10mfd, while c6 shows three 100mfd with no indication of the 10mfd.
i'm enclosing the schematic as well as a blowup of the rectifier area.
thanks,
mikeB
thanks,
mikeB
