Please excuse my newbness here but just getting into the audio game based on a set of recently acquired dahlquist d-10 speakers and a Dq-1w subwoofer from a family member. Also have the passive crossover.
I recently picked up a Yamaha P 2200 pro Poweramp and is wondering if this was a good combination, as I have read the speakers will require a lot of power. Also, I understand that you can connect an additional amp to power the subwoofer but was unsure of the right way to hook it up. Would I need a speaker wire/RCA adapter such as these to come out of the crossover "sub out" than to another amp input?
I also have the option of acquiring an emotiva usp-1 preamp with a dedicated sub out, could I use this then to bypass the crossover and go directly into an additional amp to power the sub? Is it okay to bypass or not use the passive crossover when using these speakers and subwoofer?
One final dumb question, on the Yamaha power amp it has two output controls for each Channel, is it best to just open these up all the way and use preamp for volume control, or do they need to be limited some what?
Sorry for the rambling and basic questions, just trying to learn.
Thanks
Thanks
