Should Dual Subwoofers Be Identical Models?
Discussion in 'General Audio Discussion' started by musichal, Jan 1, 2018.
  1. musichal
    11,608
    Norman OK
    My WAG is that this would be best, but what do you subwoofer gurus (and others) think? This is for two-channel use. Used for music and video sound, with music the first priority.
  2. awillia6
    awillia6 Super Member
    1,381
    Should multiple mid-range drivers in a single tower be identical? What about the drivers used in two towers?
  3. SteveA
    SteveA Super Member
    1,075
    Wellington, New Zealand
    If you are feeding them both the same signal (mono mix of L + R) then it shouldn't matter.
    If one is attached to each of L & R then how much it mattered would depend on how similar they were.
    Since bass is pretty much non directional feeding them both the same mono signal might be best.
    WaynerN and awillia6 like this.
  4. JoeESP9
    16,814
    Philadelphia PA
    Some speaker manufacturers go to great lengths to match drivers and many hand select crossover components.
    Bill Ferris likes this.
  5. awillia6
    1,381
    In that case, wouldn't it be best to break the low-end into separate frequencies which each sub would then handle on its own to reduce overall interference between competing same-frequency points sources?
  6. awillia6
    1,381
    And then they go and feed those (near) perfectly matched drivers significantly different signals (i.e. using n-1/2 way crossovers). And stereo between matched towers (or bookshelves). Does bass "image"? I'm guessing no.
  7. MoreBeer
    MoreBeer Money + Money =More Money
    627
    New Jersey - It Sucks Here
    Personally, I would use identical subs. But if the added sub is similar, such as size of the driver and cabinet type, and you're crossing over no higher than 80hz, I'm sure the earth will remain intact and the sun rises tomorrow morning.
  8. awillia6
    1,381
    Only up to 80Hz in order to minimize localization? Why would localization be a problem with duals? Wouldn't they simply (or complexly) image higher freqs? And what's the matter with imaging?
  9. sqlsavior
    6,177
    EspaƱola NM
    It depends on one's level of OCD.
    :smoke:
  10. SoCal Sam
    SoCal Sam Lunatic Member
    19,131
    Picker's Paradise
    Yes, same sub for L-R application. Non-directional bass is a bit of a myth. You will want to treat bass just like any other frequency and time align the subs with your mains for best imaging.
    Bill Ferris, StimpyWan, ben_ and 2 others like this.
  11. musichal
    11,608
    Norman OK
    Let's assume slightly above "normal" - whatever that is.
  12. MoreBeer
    627
    I would assume if they were crossed high, and each had a distinct sound, it might be somewhat annoying. But then again, never tried it with non-identical subs. Although I can say with authority that two subs not only makes a difference, but also an improvement on HT systems.
    If however adding a sub to a mainstream stereo system with substantial primary speakers, one sub crossed over low from the pre outs is really all that's needed.
  13. awillia6
    1,381
    That makes sense. You don't object to your fronts receiving and reproducing different signals, but that's intentional. You call it stereo imaging or soundstage or depth and directionality in HT. So non-localizable low freq can come from anywhere, by definition. Localizable freqs should, if accurately reproduced, yield the imaging the sound engineers mixed into the source material. Seems like you'd want clones for everything localizable (2-channel speakers come in pairs, after all) and don't cares for anything non-localizable.
  14. Katalyst
    Katalyst AK Subscriber Subscriber
    805
    Indianapolis, Indiana
    My opinion on the L+R in mono is no. There is music that have one channel bass lines. Example here between 1.50 and 2.05.
    Bill Ferris and musichal like this.
  15. JoeESP9
    16,814
    Philadelphia PA
    That's exactly why I use identical dual subs running in stereo.
  16. musichal
    11,608
    Norman OK
    Pretty compelling point.
    stish likes this.
  17. awillia6
    1,381
    But where, if anywhere, do you limit the frequency of signals sent to your stereo duals?
  18. JoeESP9
    16,814
    Philadelphia PA
    I have an electronic crossover. It has high pass and low pass outputs. I do not run my mains full range. Currently my crossover is set to ~60Hz.
  19. awillia6
    1,381
    So, if sub-60Hz is non-localizable, then the concept of "channels" does not apply to such signals, and it matters not which of any or all your subs output the sound into the listening room.
    musichal likes this.
  20. musichal
    11,608
    Norman OK
    Big if. When it starts getting around 40hz and up sound becomes easier to localize.
    stish likes this.
