herbd2
Well-Known Member
Hello,
I recently picked up an M-50 which was sold as "in protect mode"....the seller told me he caused the issue by running too many speakers at once. It only cost me $30 so I took my chances. After opening the case, I found a nest of burnt resistors on the right side, that got hot enough to melt the solder and cook the board a bit. I started by removing and testing all the resistors in that area, they all still tested OK, so for short term action,I put them back in, and resoldered them, had to add some jumpers and such on the back where the traces had been broken.
Confirmed all looked OK and matched other side. However, the unit is still in protect mode. When I power it up, it is making some kind of click/static type noise....I haven't had the nerve to keep it on long enough to figure out where the noise is coming from. Anyway I'm assuming too many speakers means too much current and hence the cooked resistors. Was hoping someone could give me some pointers on where to begin this troubleshooting journey? I did test the output transistors for any opens between base and E, but nothing showed open. Fuses are ok, unit powers up, power light and meter lights come up, but with the funky sound I've never left it on for more than a few seconds....
