So, I need a new Subwoofer
Discussion in 'Home Theater & Video' started by peerson, Mar 12, 2019.
  1. peerson
    peerson Super Member
    1,068
    Kansas City area
    Found out today that my Klipsch SW450, powered Subwoofer cannot be repaired. It was affected by a lightning strike last Fall. So, I need a new one. And, I am looking for recommendations. This is for a HT system. Thanks in advance!
  2. sKiZo
    Not a big fan of woogers myself - up your nose, they tickle, and in your mouth, they get stuck between your teeth. I can see where some folk might like them though. Maybe stick them under the seat and save them for later ...
    (Not sure where a subwooger would go though ...) ;-}
    How badly damaged was the sub? If it's just the amp board, maybe check out Dayton Audio's DIY kits for a replacement that will fit? All different watts ranges available and some neat features such as adjustable pass filters and such. Hard to beat their prices too.
  3. jbrainey
    jbrainey AK Subscriber Subscriber
    5,007
    I get my mail in Tennessee
    Maybe a new raccoon is all they need? :dunno:
  4. peerson
    1,068
    Kansas City area
    I will find out which board is bad when I pick it up. Hopefully this week. And, no, I will not need to raccoon the woofer on this one
  5. Gazdatronik
    Gazdatronik Super Member
    1,528
    Chattanooga TN via Chicago
    SVS 2000 series would be my pick. Goes down to 15hz, and best value for money out of all their offerings.
    Harvestor likes this.
  6. bigx5murf
    bigx5murf AK Subscriber Subscriber
    1,471
    Las Vegas
    If it's only the amp that's fried. If you have a spare amp laying around, you just just drill and install some binding posts on the cabinet, and hook it up to the woofer, turn it into a passive sub.
  7. Duane
    Duane AK Member Subscriber
    3,876
    San Diego
  8. Grenadeslio
    Grenadeslio Super Member
    4,035
    I
    In my recent move one of my Daytons wouldn't power on, the plate amp is no longer made. Ordered two plate amps to replace both to keep the pair identical, wouldn't you know it the defective unit started working and hasn't skipped a beat in 8 months now. So now I have 2 Dayton plate amps in the batters box lol.
  9. sKiZo
    I use a Dayton plate to drive my butt woofers ...
    Some might know them better as bASS Shakers? Two of the Aura Pro transducers anyway. Only problem is I got too big a plate amp and I could just barely crack it open before my lazyboy starts to shake apart. Added an inline attenuator between that and the light show controller that feeds the chair and all is good now.
  10. peerson
    1,068
    Kansas City area
    I think I will call Dayton to ask which one might be a good fit for my Klipsch. Looks like an easy replacement if they have one that will fit without too much modification.
  11. transmaster
    transmaster AK Subscriber Subscriber
    8,686
    Cheyenne, Wyoming
    Check with Klipsch they do sell replacement amp's
    You might also look at the SW-450's replacement, the
    Klipsch Reference R-10SW 10" 300w Powered Subwoofer. It is on sale at Amazon for $249 Dollars.
  12. peerson
    1,068
    Kansas City area
    According to my tech, the parts are not available from Klipsch anymore. The R10SW looks interesting. Will probably check that one out
  13. twiiii
    twiiii Addicted Member
    6,951
    west Texas
    Remember the total displacement of your sub should be 4 times the volume of your satellite speakers woofers. So if you have 8. 8 inch woofers that move 1/4 of an inch. Thats. 16 pi X 8 X .25 = 32 pi cu inches. X 4. or 128 cu inches. If a 12 inch woofer can move . 5 inches. That would mean 36 pi X . 5=. 18 pi. which .means you would need 7 subs.. If your subs have 1 inch travel you could get buy with 4. If you used M&K subs with double 12"'s you would need two. If you used Klipsch I would want 2 15 inch subs to get the full capability of the system. If you are like most folks one 15 inch would probably suffice.
  14. slovell
    slovell Active Member
    359
    Chesnee, SC
  15. Silentnet
    1,180
    Charleston, SC
    Td;Dr:
    Everyone needs 10 subs.
    Needs.
  16. Grenadeslio
    4,035
    D
    Damn, I only have 3.
  17. twiiii
    6,951
    west Texas
    Its all about the volume of air needed to be moved. Maybe a professional JBL system where the woofer can move over an inch. Of course if you listen with sustained levels less than 90 db and you wish to give up bass below 30 HZ a Single 12 will be all you will ever need. But remember two subs placed properly in a room will be more apt to give the most even coverage throughout the listening area.
  18. Audiofreak71
    Audiofreak71 Boerboelicious Subscriber
    2,700
    PNW
    The volume of air or a whole lotta watts to make up for a smaller box . I had 2 Velodyne HGS 12’s now I have one they put out 1,250 watts rms and 3,000 watts peak and dual spiders instead of a bumped pole for a much higher excursion. In other words these things can get very low and loud , no need for 2 in your average room and not that that will break your windows . I agree that 2 subs are better for smoothing out the low end frequency.
    Audiofreak71
  19. peerson
    1,068
    Kansas City area
    Ordered THIS from Amazon. Supposed to deliver Tuesday. Been without one since the power surge last June!
    transmaster likes this.
  20. transmaster
    8,686
    Cheyenne, Wyoming
    I very much like Klipsch subwoofers. I have a RW-12II it has been causing earthquakes since 2013.
