cizeta
Member
I am a Sony engineer and I have a CDP302ES since 1986 (30 years old). By technical I had access to confidential technical publications of Sony and I have replaced, over the years, the chip CX23035 (signal processor) with the most modern CXD1125Q, (pin to pin perfectly compatible), which is equipped with digital output (pin 27- DOTX) and plugged two PCM56P-K instead of the CX20152 DAC, being unique for the two channels (UNI linear converter), working alternately causes a technically annoying delay of approximately 5.67 microseconds between the left channel and the right channel, eliminated by the two DACs separated. Its operation is still impeccable and the sound is at the highest levels of quality. Tried instrumentally far it exceeds the linearity and intermodulation distortion (CBS CD-1 TEST DISC track 13) of the current bitstream readers. The sound of PCM56P is recognized as excellent.
