For those that own these decks, correct belt size can be hard to find. Most online retailers list a 23.6 as proper..nope. The motor mounts on these decks are pretty soft and that size belt puts way too much pull on the motor. I found the proper belt to be 25"/ 64cm. My table still runs 1.5 seconds fast in 1 min with this belt, and I don't think there is any speed adj. other than turning down the drive pulley.
The service manual lists a part number for the belt that contains a "64", I assume a length in centimeters.
Hope this helps someone.
P.S. the flopped out belt I removed measured 25.2", which was barely working, as in not riding the high point on the pulley.
