zuhmuguh
New Member
I have a Sony PS-X7 turntable that runs fine as a manual, but recently I wanted to try and restore its automatic functions. Before my repair attempt, the table would not automatically cue, would only occasionally automatically return at the end of a record, and touching the start/stop button mid-operation would not stop the platter. After reading every pertinent thread on AudioKarma about PS-X6/X7 repairs, I went in and degreased all of the gunked up parts and regreased with white lithium. While I had the machine open, I also applied DeoxIT where I thought it may have been needed.
Upon putting it back together, it seemed like the cleaning had worked: the auto cue was working (albeit dropping in to the wrong spot), and the auto return worked as it should have. I followed the service manual's guide to adjusting the drop-point, however I think my screwdriver bumped into another part while I was trying to make the adjustment. Since then, all automatic functions on the table are no longer operable, although it does run fine manually.
I was hoping someone on here may be able to help me out! My theory is that I may have nudged the brake drum/shutter assembly out of place, but I'm not quite sure what position it should be in. If anyone could provide a picture, that would be fantastic.
