Sony STR7800 SD
Discussion in 'Solid State' started by wmgwizard, Dec 16, 2012.
  1. wmgwizard
    wmgwizard AK Subscriber Subscriber
    2,904
    Browns Mills NJ
    I have had this piece for a little while and in the beginning everything was fine.
    One day after a few weeks of non use I hooked her up and got no sound.
    Lights up, tunes stations, no relay click.
    The biggest problem for both my tech and myself is there is no schematic available. It is not included in the service manuals we were able to find. My tech even checked with his contacts at Sony with no luck.
    Anybody have a schematic for this or know where I might get one?
  2. ryuuoh
    ryuuoh FFXIV Summoner Subscriber
    9,227
    Marina CA, USA
  3. Guest101
    Guest101 Super Member
    1,387
    There is a big difference between the 7800 and 6800.
  4. wmgwizard
    2,904
    Browns Mills NJ
    Thanks for the suggestion but the little information I have found indicate significant differences in the 7800's design specific to this particular model.
    It may be closer to the V-7 or V-9 than the 6800.
  5. wmgwizard
    2,904
    Browns Mills NJ
    anyone?
    please?
  6. petehall347
    21,714
    uk.. the middle bit
    if i get chance i will look through the sony manuals i have hundreds but they aren't in proper order .. last 2 i looked for i didn't have ..maybe this will be 3rd time lucky ...thing is my manuals are for uk stuff .. so don't hold your breath .
    topology is much the same for amps . so shouldn't be to difficult for your tech to find why its in protection ..
  7. wmgwizard
    2,904
    Browns Mills NJ
    @Petehall347:
    Thank you so much for trying, any help at all is greatly appreciated. Thank You
  8. Turnergande
    Turnergande Active Member
    132
    The STR7800 SD servive manual I have was downloaded free via hifiengine.com Maybe still available there?
  9. wmgwizard
    2,904
    Browns Mills NJ
    The manual is listed as incomplete, it has everything BUT the schematic.
    If your copy has a schematic I would really appreciate a copy
    Thanks so much for trying
