Speaker hum caused by my receiver
Discussion in 'General Audio Discussion' started by Signal-Green, Jun 25, 2008.
  1. Signal-Green
    Signal-Green New Member
    32
    Sacramento, CA
    I'm a newbie to receiver maintainance.
    I get a hum through any speakers I use only with this HK receiver ever since I bought it used. After 2 seconds on, the hum loudness drops to half strength and stays there; but its still loud. I've tried alot of configurations. Its there no matter what knobs I turn; and with nothing connected to it.
    FYI - there are 3 fuse knobs on the back, and a GND screw.
    Any simple things I can try? Thanks.
  2. toxcrusadr
    26,948
    Central Missouri
    What's the model # and approx. age?
    Does the volume of the hum change when you change the volume knob?
    You might have failing filter capacitors in the power supply.
  3. westend
    westend Audiopile
    10,149
    Shorewood MN
    You could try running a wire from the chassis ground screw to the faceplate screw on the receptacle it's plugged into. That might cause more hum or it might eliminate it. It's an easy thing to try. Another thing to try is looking inside the receiver and look for any oxidation on any of the chassis grounding points. Tighten down the transformer, also.
    Besides these grounding issues, most hum problems are causd by a failing/failed capacitor and that is a little more work to nail down. Look for any bulging or leaking caps.
  4. Signal-Green
    32
    Sacramento, CA
    Interesting you should ask. That was my next thread. But I just opened the receiver and found this printed inside: "APR2967. I assume thats a date. Model says "Two Hundred" on the front. On the bottom is says THK-21.
    No(edit: Yes - on phono and phono mono, but not tape.)
    It's my 1st time opening a receivr, so I don't know what a transformer looks like.
    there's a little red and brown stuff on them.
  5. cademan
    cademan Addicted Member
    8,054
    If you don't know what a transformer looks like, it might not be a good idea to go poking around inside. If you want to learn, now there's a good idea.
  6. titanstats
    titanstats Go Habs Go!
    4,414
    Vancouver
    Try flipping the plug over, seeing if the polarity change will help, if not, try using a different electrical outlet. Do you have your cable hooked up to it for FM? That can give a hum, as well as your computer, if it's hooked up. Sometimes it's the little things...
  7. Signal-Green
    32
    Sacramento, CA
    I'm tried all the above and still have the hum.
    I was mistaken on one thing: The hum DOES increase in volume as I turn up volume - on phono and phono mono, but not tape.
  8. westend
    westend Audiopile
    10,149
    Shorewood MN
    Are you using a Turntable? What is the condition/type of interconnects you are using? Give us a little more infromation about your system
  9. terra1
    terra1 Addicted Member
    5,336
    WA
    Does it get really hot to the touch?
  10. x_25
    x_25 Big Vandies!! Mwahahah...
    6,758
    Northern NJ
    Try flipping the plug around. Even though the plug for the wall is non polarized, some times it can cause a hum if it is in backwards. As for the phono hum, if you have a Turn table hooked up do you have the ground wire for the turn table connected to the receiver?
