Im working on a Lafayette 250a integrated amp. The schematic link is for the kit version, KT250a. Same, but legible. The bias drifts some, not much, but enough. It always changes on startup. it can be .45 or it can be .50.All caps have been replaced, resistors have been checked for odd man out, those tied to the bias circuit replaced. All tubes have been swapped and/or replaced with others. The problem is most prevelant on the left channel. All pots have been cleaned. The balance and bias pots look like dual gang, but work individually, and i cannot source new ones. The left side feels a ever so slightly looser than the right. It seems extremely sensitive, as if just touching it with a screwdriver causes it to change. Ive opened them up and they are nice and clean. I had considered opening it up again, and tightening the contact a bit. Stock pots are 10k for bias and 5k for balance. Theres not much room to put in seperate pots. I have a pair of 2x10k i can try. Would the 10k section work for the 5k? Perhaps with a simple mod? I am giving this to a tube newbie friend, so i need to be sure it will be stable.
Oh, and Happy Thanksgiving
http://www.freeinfosociety.com/electronics/schemview.php?id=2382
