olddude55
Super Member
Applies to 1219s and 1229s Q and non-Q.
The single/multi play lever broken dearing ring thing...what does the rubber washer do that causes so much bad stuff to happen? It's not a spring, is it?
When it hardens or gums up, does it prevent the two ball bearings from turning?
I'm rehabbing a 1219. Dearing ring is intact but the single/multi lever is stuck on single play. I know better than to force the lever, but when I look at the rubber washer (which has harden up pretty good), can't figure out what it does that causes the ears to break off the dearing ring.
