aldena007
Legacy Audio Aficionado
I am in the process of repairing a pair of F2624 Driver Circuit Boards from a QRX-9001. As part of my repair I decided to test the STV-3 diodes on both boards. The expected voltage drop on my test rig was 1.5 ~ 1.8 vdc. The voltage drop I measured was 2.2 vdc. I got this on all four of the diodes off of the two boards. To verify my test rig I tested a diode from the supplier in Germany who is selling on eBay. This diode did test good with a 1.6 vdc voltage drop. The OEM diodes off of the F2624 boards are marked with the yellow dot but the body is reddish brown. The one from Germany has the yellow dot [cathode] but the body is black.
Are the brown diodes really STV-3? If not, should I switch to the black bodied diodes in my restoration?
