My story:
I had the same issue on a Spec 2 when I replaced the filters. They were installed correctly but the one connection at the screw terminal had very poor crimp on the ring terminal. I usually follow up with solder but was in a hurry. The symptom that manifested was the inability to set the Idle on that channel after replacing the big caps. The set was complete and had been running on the break-in bench for a week and was stable as the days long. All the amp adjustments, limiters, everything, were made and spot on. I was waiting for the large caps to arrive and install them before it was considered complete.
Now, it wasn't that I couldn't set the Idle, it was very touchy and hardly any CW turn from full CCW got to the .030v's idle. I thought - well it's stable, a little funky (It was perfect before
) - but it works. Go with it. Bad decision.
Guess what? After running a 1Khz signal and increasing the gain slightly while watching the scope. Pop and Smoke!!
R21 let go. Which is a Spec 2 amp resistor that shares a similar function as R24 in the 1250's circuit.
I said you may of installed the filters incorrectly but the connections should be checked for good contact and make sure to use proper electrical connecting techniques.
But that's the small issue now. The Amp driver board will consume some time to sort out.
Mark (MTF) probably see's something I missed. He's all knowing in these matters.
Order up the rebuild list and ask questions if unsure. The set will be better for in the end. And you will have a smile knowing you messed up and then fixed it.
Plan on using good tooling. No reason to chimp out, because this repair thing is addicting and it may not be your last one. Lots of threads on what tools to buy, here on AK.
