I am fixing up a nice SX-737. It has the AWE-043 tuner board. I've successfully replaced "problem" transistors (725/726/1451) on the other boards, but have done nothing to the tuner board.
Can you guys help me with a definitive answer about replacing components on the tuner board? Is there a definitive answer? Here's what I've read:
* Don't touch anything on the tuner board (not even the 2SA725 transistors) unless you're prepared to do an alignment.
* It's okay to replace capacitors on the tuner board, but don't touch anything else (especially transistors) unless you're prepared to do an alignment.
* It's okay to replace the C49/C50 capacitors, and Q8/Q9 transistors (markthefixer wrote "replacing those four components will have NO effect upon alignment") but nothing else should be replaced.
And I think I've read other permutations, including guys who've gone ahead and replaced everything with no re-alignment required. If markthefixer's comment above is correct, is it true that the Q10/Q11 2SA725 transistors should NOT be replaced...just the Q8/Q9 2SA725's?
