rocknroller
Have this sa-800. When changing the mid eq off it's center/null point, I get a slight momentary pop. I do not believe this is a issue of dirty control. Have sprayed (as best as I could get there without dissasembly - eq board is very difficult to access on this model) and I'm very familiar with what a dirty pot sounds like. This is different. The pop only occurs when moving from the null point , 1 click in either cut or boost direction. All other movements after that are fine. It seems to be occurring when the circuit is being engaged. There is no similar issue with the bass or treble movements.
Looking at the schematic (below), I checked esr on the surrounding caps, nothing seemed unusual until I got to C521 (Red square) and the uf reading didn't match the schematic. I then realized I was looking at a 800a schematic. When compared to the original 800 schematic I found these 4 differences (marked). The original C421 cap is a 0.68uf. The original resistors are R535 56K, R533 1K, and R563 180K. Obviously, Technics changed these for a reason, but is that that popping due to the original circuit design, which the 800a circuit addresses, or was that circuit change for something else? (and if something else what? And then what could be the cause of my issue?) Thanks in advance for any useful input!
