Technics SL-2000 vs SONY PS-LX 300H
Discussion in 'Turntables' started by yilmazcan, Jul 10, 2009.
  1. yilmazcan
    yilmazcan New Member
    46
    Hi,
    I have two alternatives: Technics SL-2000 and SONY PS-LX 300H. Any body can compare these?
    Specs of sony is in the picture format.
    Technics' is:
    Motor: low speed electronically controlled brushless DC motor
    Platter: 30cm aluminium diecast
    Speeds: 33.33 and 45rpm
    Speed change: electronic change
    Pitch control 10% adjustment range
    Wow and flutter: 0.045% WRMS
    Rumble: -70dB
    Tonearm: Universal S-shaped tubular arm
    Effective length: 220mm
    Overhang: 14mm
    Weight: 12 kg
  2. Balifly
    Balifly Listening Subscriber
    16,149
    Vancouver, B.C., Canada
    Take the direct drive, one less potential problem.:thmbsp:
  3. rito25
    rito25 Super Member
    1,723
    Technics all the way.
  4. kotofei
    kotofei permanent gear evolution Subscriber
    If I were you I would go with Technics since it is heavier that a Sony (12 kg versus 7) and have slightly better specs.
    It's interesting that a turntable named Sony PSLX300USB is on sale on ebay now and yes, it's USB. It looks differently from the PS-LX 300N that you are considering HOWEVER to have a USB relative is a bad sign.
